FWSM: Tcp connection timeout per service?
Answered Question
Jan 31st, 2008
I was used (netscreen) that I could set a tcp connection timeout per service, e.g. custom service tcp/9444 timeout 02:00:00.
But with the FWSM I could only specify a connection timeout for all tcp connections? Is that true or is there a way to specify it only for certain connections?
Correct Answer by Jon Marshall about 9 years 5 months ago
It depends on which version of code you are running on your FWSM. Roughly speaking
2.x = pix 6.x
3.x = pix 7.x
On pix 6.x you could only set the timeout globally for all tcp connections. With v7.x you can do it on a per port basis. So if you have v3.x on your FWSM yes you can do this.
See attached link for more details
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/mpf_f.html
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Thu, 01/31/2008 - 02:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
2.x = pix 6.x
3.x = pix 7.x
Jon
