PIX 515e Flash out of space
Answered Question
I just upgraded a PIX 515e w/ 64MB RAM and 16MB flash from 6.3.4 to 7.2.2 and then to 8.0.3.
Here's the contents of my flash:
pix# dir
Directory of flash:/
3 d--- 384 09:16:26 Jan 30 2008 lost+found
7 -rw- 7280640 12:15:44 Jan 30 2008 pix803.bin
16128000 bytes total (4195328 bytes free)
pix#
I tried running "fsck" and it checks out fine. I'm trying to upload the ASDM file and "should" have enough space. The configuration is not long at all. Any ideas of what is taking up the extra supposedly empty space?
Correct Answer by cisco24x7 about 9 years 3 months ago
do this:
1- copy flash:pix803.bin tftp
2- format flash:
3- copy tftp flash:pix803.bin
Now you will have free space in the flash:
CCIE Security.
Overall Rating: 5 (1 ratings)
srue Thu, 01/31/2008 - 06:03
  • Blue, 1500 points or more
whats in the lost/found directory?
This is interesting, I tried to cd to the directory and it gives me an error. I also tried to delete the directory and it said it couldn't because its not empty. Any tips?
pix# rmdir lost+found
Remove directory filename [lost+found]?
Delete flash:/lost+found? [confirm]
%Error Removing dir flash:/lost+found (Directory not empty)
pix# dir
pix# cd lost+found
pix# dir
%Error opening flash:/lost+found/ (No such file or directory)
Correct Answer
cisco24x7 Thu, 01/31/2008 - 09:52
  • Silver, 250 points or more
do this:
2- format flash:
CCIE Security.
