ACS Problem
Jan 31st, 2008
I have 2 ACS SE, one primary and the other secondary. when I've configured them, all operation seems completed correctly, clients can authenticate successfully. but when I restart them,no authentication is performed, I cheked the Network Configuration page in the Primary ACS and I detect that the following is added to the AAA servers"self with an address 127.0.0.1". the address is unchangeable neither the Secret key.
any one have some idea?
thanks
acharyr123 Thu, 01/31/2008 - 04:18
When u add the ACS in AAA Server option at Network Configuration u will get "Self" for ACS with the IP of the device...not 127.0.0.1
It seems both these devices are nt configured properly in active/standby mode.
Please try to add the same with the exact IP of the primary ACS..It should work!!!
Rate if it helps!!!
ismail884 Thu, 01/31/2008 - 06:55
I've used the Engine Recovery CD. and I reconfigured the ACS.this time I verified that all thing is working properly. I configured the IP address and I restart the ACS many times.
thank you
Ismail
