DSL controller problem
Jan 31st, 2008
I've a problem with my DSL controller, I configured this one but the controller is flapping UP-DOWN-UP-DOWN, I tried several parameters but still NOK, have you an idea why? Thanks in advance.
HERE's my config.
controller DSL 0/0/0
mode atm
line-term cpe
line-mode auto
dsl-mode shdsl symmetric annex B
Do it can be due to the firmware on the controller?
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Thu, 01/31/2008 - 02:57
When reporting problems, at the minimum, always include router model and exact IOS used.
yavuz.ozdemir Thu, 01/31/2008 - 04:54
Sorry, here's more info. :
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(17a), RELEASE SOFTWARE (fc)
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FCZ120273RJ
1 DSL controller
2 FastEthernet interfaces
4 ISDN Basic Rate interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
yavuz.ozdemir Thu, 01/31/2008 - 04:55
Router#sh controllers dsl 0/0/0
DSL 0/0/0 controller DOWN
SLOT 0: Globespan xDSL controller chipset
DSL mode: Not Trained
Frame mode: Utopia
Configured Line rate: 4608Kbps
Line Re-activated 53 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
FPGA Revision: 0xB2
Line 0 statistics
Current 15 min CRC: 0
Current 15 min LOSW Defect: 0
Current 15 min ES: 0
Current 15 min SES: 0
Current 15 min UAS: 180
Previous 15 min CRC: 0
Previous 15 min LOSW Defect: 0
Previous 15 min ES: 0
Previous 15 min SES: 0
Previous 15 min UAS: 871
Line 1 statistics
Current 15 min UAS: 203
Previous 15 min UAS: 737
Line-0 status
Chipset Version: 0
Firmware Version: R3.0.1
Modem Status: Handshake, Status 10
Last Fail Mode: No Failure status:0x0
DSL firmware download in progress, please wait
Line-1 status
Chipset Version: 0
Dying Gasp: Present
