tsteger1 Thu, 01/31/2008 - 13:16
The "Roaming - Force VPN [V5.2 r245]" rule module has most of this set up already.
Just make a similar rule module that only has the 'System booting' system state and go from there.
Tom
jan.nielsen Fri, 02/01/2008 - 09:20
Just remember that "System Booting" is not defined by "when does my login prompt appear" but is active until all services have started on your windows box. Also i believe that Roaming VPN is using a dynamic application class that won't actually enforce the 5 minute rule, since it will just give you another 5 minutes if you close the application and open it again, since the "add process to class" rule is enabled in all system states.
