Inbound Call Control
Jan 31st, 2008
Hi!
I have defined Meet-Me number. How can I restrict access to this number (calls from PSTN), in the way that only specific external telephone number can access this pattern?
Is this possible?
thx
Paolo Bevilacqua Thu, 01/31/2008 - 04:24
  • Hall of Fame,
    Founding Member
Do you have CME or CM and which version., If the latter are you using H.323 or MGCP to the GW ?
Zin.Karzazi Thu, 01/31/2008 - 06:24
  • Silver, 250 points or more
If you have Unity or IPCC , you can do a supervised transfer, where the User should provide a PIN and tell his Name before he get connected to the Meet-Me conference.
There is no other solution for this problem.
