G703 Configuration
Jan 31st, 2008
how to configure G703 ethernet interface ,in background of this many different locations are connected with one G703 interface, Kindly advice.
spremkumar Thu, 01/31/2008 - 06:15
can you revert on what type of circuit is being subscribed on the G.703 interface ?
Paolo Bevilacqua Thu, 01/31/2008 - 06:21
Ethernet is not G.703. E1 and T1 are G.703 interfaces, however cisco refers to unframed E1 as G.703.
This is called channelized configuration (propert ITU name is G.704) and is a service that you obtain from you carrier:
controller E1 x/y/z
channel-group 0 timeslots 1
channel-group 1 timeslots 2
interface serial x/y/z:0
ip address ...
hope this helps, please rate post if it does!
adnan.dhl Thu, 01/31/2008 - 21:45
Hi p.bevilacqua
Thank you for your reply.i can little bit understand kindly inform me in little detail, how can distribute the bandwidth with each channel.if you don't mind kindly give me the sample configuration of that type of interface.
