Does this "sh DSL int atm 0" look right?
Jan 31st, 2008
Hi, I have an office on a VPN DSL line of 1mb downstream and 288kmps upstream and the ms can be around 500. Before we upgrade the line can you see anything wrong with this output?
sh dsl interface atm 0
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x03 0x2
Vendor ID: 'STMI' 'TSTC'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0xB5
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 61% 38%
Noise Margin: 9.0 dB 22.0 dB
Output Power: 15.5 dBm 12.0 dBm
Attenuation: 55.0 dB 27.5 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x3D
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 12384 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_AMR-3.0.014_no_bist.bin
Operation FW: AMR-3.0.014.bin
FW Source: embedded
FW Version: 3.0.14
Interleave Fast Interleave Fast
Speed (kbps): 0 1152 0 288
Cells: 0 5317638 0 1545657
Reed-Solomon EC: 0 0 1 4
CRC Errors: 0 1966 5 0
Header Errors: 0 1049 6 3
Total BER: 0E-0 1842E-9
Leakage Average BER: 0E-0 5366E-10
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Disabled
paolo bevilacqua Thu, 01/31/2008 - 06:24
  • Hall of Fame,
    Founding Member
Nothing is wrong and you are running recent firmware, that is good.
