01-31-2008 06:26 AM - edited 03-03-2019 08:30 PM
When i reinstall the CCM, i got this problem for Database Access Security.
I must configure the security password for each cluster and when I click next, the installation got to be error and the error message is "Security COnfiguration Failed [1]
02-06-2008 08:08 AM
The reason for this is that version 4.2 contains some extra functionality that is not yet available in 5.0, and it is intended for people that want to stay on the Windows platform for several years to come.
If you are running 4.1, you can go ahead and install the CCM 5.0(4) and perform the upgrade as outlined at
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/install/upgrade/dmaug504.htm#
02-27-2008 06:03 PM
I am also attempting to install CCM5.1 and receive this error during the initial install. It occurs regardless of if I select to upgrade or a fresh install.
Does anyone have any further info on this? Does the security password have to follow any additional requirements other than those stated? Or does it have to do with something else?
Ta,
02-27-2008 09:25 PM
i've already solve the problem.. my installation cd is corrupted, after we replace with another CD, it is working fine
