Can I upgrade a C1861-SRST-F/K9
Jan 31st, 2008
Can I add a AIM-CUE to a C1861-SRST-F/K9 bundle ... I purchase the wrong bundle and I need VM ... Configurator doesn't allow the upgrade the router and I don't see a licence ... I wanted to know if Cisco supports this upgrade ?
paolo bevilacqua Thu, 01/31/2008 - 06:59
  • Hall of Fame,
    Founding Member
I think that nothing prevents a regular AIM-CUE to be fit in the router and work with the appropriate SW image.
paolo bevilacqua Fri, 02/01/2008 - 12:50
  • Hall of Fame,
    Founding Member
You are right, but knowing cisco, I think the AIM-CUE that sells as spare, is the very same that goes as optional with the 1861.
peraocompany Sun, 06/26/2016 - 14:49
No, 1861 have not any AIM slots inside. CUE processor and DRAM/FLASH slots are included in SRST-F bundel on main PCB. How upgrade it I dont know.
