IP static routing question for a VPn
Answered Question
Jan 31st, 2008
I have an IPSEC VPn to a site at another company. I would like to add a static rout in our VPn router, pointing to one of the subnets on the interior of our IPSEc peer's network. But, I'm not sure what the next hop should be for the static route -- should it be the other end IP for the IPSEc tunnel?
This is a non-gre tunnel.
Thanks!!!
Correct Answer by sivakondalarao about 9 years 4 weeks ago
yes, it will be the other end IP (or peer IP).
regards
skrao
Overall Rating: 5 (1 ratings)
