Is this normal CPU% on FWSM
Jan 31st, 2008
I got a 6506-e with fwsm module.
I get around 80 connections per sec, mainly UDP.
The proc is constantly at 20-22%
Is this normal for these connections?
How do I troubleshoot this?
Overall Rating: 3 (1 ratings)
excession Thu, 01/31/2008 - 10:17
I'm not sure if it is normal.
Please take 3 outputs of "show proc" each 60 seconds appart and post.
Also if possible please post "show run" without sensitive information? What type of traffic are you inspecting?
If you do a "show pc conn" what connections do you see? Is there one type of traffic in particular? Again if possible post the output here?
pallette Fri, 02/01/2008 - 12:26
Is this FWSM running in single or multiple context mode?
cisconoobie Sun, 02/10/2008 - 11:20
I fixed the problem.
There were about 80 DNS UDP requests passing through the FWSM per second.
inspect DNS maximum-length 512 - was enabled and this killed the CPU%
I disabled DNS inspetion and CPU dropped to 0%
I'm happy that the problem is fixed but it sucks that the FWSM cant handle this inspection properly.
