Difference between Cisco 6509 and Cisco 6513 switch
Jan 31st, 2008
Can someone plz guide me the technical difference between the 6509 and 6513 switch like the support od single slot, dual slot, backplane speed and the other things i dontknow...
Edison Ortiz Thu, 01/31/2008 - 09:34
  • Hall of Fame,
    Founding Member
The main thing is the backplane.
The 6500 Series support up to 720Gbps backplane speed. However, that number is full-duplex which in reality is 360Gbps.
Therefore, 6509 will support 9 modules with dual fabric connection to the backplane. Dual connection is 40Gbps * 9 = 360Gbps.
Then it comes the 6513. You have the same limitation of 360Gbps and you have 4 additional modules to contend with. Then it was decided to allocated 5 modules (9-13) with dual fabric (40Gbps) and 8 modules (1-10) with single fabric (20Gbps).
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd80673385.html
HTH,
__
Edison.
tmsundar81 Thu, 01/31/2008 - 09:44
Thanks a lot look like i need some time to gothrough it.. :)
