MtpNoMoreResourcesAvailable
Jan 31st, 2008
  • Bronze, 100 points or more
I was looking over a CCM 4.1(3)sr4d system and seen they have some MtpNoMoreResourcesAvailable errors. They are getting them every so often. Like today they've had 7 in about 4 hours.
If I list their MTPs, there are 2 listed. When I look at their Media Resource Groups, they just have one. When I look at the MRG, the selected Media Resources is 1 of the 2 MTPs and it's the (MOH). Could these errors be eliminated if I would add the second MTP as a Media Resource for the MRG? Thanks!
Jaime Valencia Thu, 01/31/2008 - 13:26
  • Cisco Employee,
  • Hall of Fame,
    2011
devices use media resources via the MRGL, they look in first place at the one located at device level, then at device pool level and finally at the default list (all resources not assigned to any MRG)
if the MTP is NOT in any MRG devices should be able to use it anyway as part of the default list
in any case you can try adding it to the MRG and see if that help
