CP-7921G Phone and AP1242AG Access Point
Chuan Liu
I have a CP-7921G phone that cannot connect to AP1242AG. It keeps saying "locating network services". (I think if the WEP key does not match, "authentication failure" will display.) But it is working well with BR1310G bridge. The configurations are identical in these 2 devices.
On the bridge:
dot11 ssid ABCD
authentication open
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxx transmit-key
encryption mode wep mandatory
ssid ABCD
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root access-point
antenna receive right
antenna transmit right
world-mode dot11d country NZ both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
On the AP:
dot11 ssid ABCD
authentication open
dot11 network-map
power inline negotiation prestandard source
no ip address
no ip route-cache
encryption key 1 size 40bit xxx
transmit-key
ssid ABCD
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
Can anybody see any configuration errors?
What do you advise me to do next?
Thanks.
Not applicable
I don't see anything wrong in the configuration. I have come across couple of bugs regarding this error message. Check for interference in you locality and try changing the channel number. Also try upgading the firmware of the phone.
It was an encryption key error.
It is working now.
Thanks.
Should not use the same SSID w/ different authentication/encryption credentials. On the bridge you have WEP128 and on the AP you have WEP40. The phone can only be configured for one or the other.
I see you are located in New Zealand, therefore have the -W model phone, which requires world mode to be enabled.
I do see it is enabled in your ap config, which is necessary.
ricardo-morales
hi i have the same but the phone is continuing authenticating with AP, some body can help me....
