No Caller ID with Cisco CME
olivier.bedard
We do not receive the CallerID on our system. We do receive the calling number, but not the calling name.
We opened a support ticket with the telco and they confirmed that they were sending the information down the pipe.
Here's the configuration of our interface:
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
isdn incoming-voice voice
isdn supp-service name calling
isdn bchan-number-order ascending
isdn outgoing ie facility
no cdp enable
We are running:
12.4(11)XJ4 / CME 4.1(0)
Here's an example debug log of an incoming call:
ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x00D8
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A1080201010201008400
Calling Party Number i = 0x2180, '5145551234'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '2505'
Plan:Unknown, Type:Unknown
ISDN Se0/0/0:23 SERROR: isdn_get_name_from_gtd: false ret
ISDN Se0/0/0:23 SERROR: process_pri_simple: NO name in GTD
ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80D8
ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x80D8
ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x80D8
ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00D8
ISDN Se0/0/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0x85
Thank you!
6 Replies 6
paolo bevilacqua
in short the switch is telling you that the name is not available. Why, you should ask telco. Here's the relevant part of your trace decoded, in the unlikely event you meet some telco technician willing to discuss it.
0x9f Service Discriminator: Network Extension
0x8b Component Type: Interpretation
0x01 Component Length
0x00 Discard Unrecognized Invoke Components
0xa1 Component Type: Invoke
0x08 Component Length
0x02 Invoke ID Tag: Universal Integer
0x01 Invoke ID Length
0x00 Invoke ID Value
0x02 Operation Tag: Universal Integer
0x01 Operation Length
0x00 Operation Value: Calling Name
0x84 Argument Tag: Context-Specific NameNotAvailable
0x00 Argument Length
The router comes to the same conclusion as you can read in clear text:
I've shameless copied the decode from a source readily available on the web. Nonetheless, please rate this post if it helps you!
Thank you for the reply.
However, what if my telco is 100% certain they send the information ?
I've been told by the technician that the info was sent "through the standard facility, not through a q931 message".
Does that make senses to you ?
benwsegura
Here is an example of the output we recieved when we performed a debug isdn 931q command. The % signs represent the callers number and name displayed. I changed them for privacy.
To me, it looks like you are not getting the info from the carrier. You may want to check with them. CLID on a PRI is in the D channel, channel 24. Channels 1-23 are your B channels.
Oct 25 11:23:50.495: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0037
Standard = CCITT
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2183, '3%%%%%%%%0'
Called Party Number i = 0x80, '4500'
Oct 25 11:23:50.519: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8037
Oct 25 11:23:50.527: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8037
Oct 25 11:23:50.691: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0037
Facility i = 0x9F8B0100A117020101020100800F47454E4E55534F204348524953544F
0xA117020101020100800F47454E4E55534F204348524953544F
Invoke Id = 1
Operation = CallingName
Name presentation allowed
Name = G%%%%% CH%%%%
Oct 25 11:24:02.607: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8037
Oct 25 11:24:02.631: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0037
Oct 25 11:24:02.635: ISDN Se0/0/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0x4F
Oct 25 11:24:02.635: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3%%%%%%%%0 N/A
Oct 25 11:24:06.367: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x0037
Cause i = 0x8090 - Normal call clearing
Oct 25 11:24:06.371: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 3%%%%%%%%0 , call lasted 3 seconds
Oct 25 11:24:06.371: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x8037
Oct 25 11:24:06.391: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0037u all
Woops! Privacy violation above , any bytehead can still read the name in hex :)
Sorry about that. Which lines do I need to edit?
Too late for edit. Mine was only a jokeful remark !
