Basic Console Connection Question
Answered Question
Jan 31st, 2008
Since some laptop manufacturers are opting not to include a serial com port in their product, I'm wondering if there is an adapter that will allow a connetion from any of the other more popular port types (USB, Firewire, or even from a ethernet port, etc) to the console port for initial configuration?
If not, what happens when serial com ports no longer exist??
Correct Answer by Jon Marshall about 9 years 3 weeks ago
One other thing to note is that with the USB to serial cables i have come across you cannot send a break which you need to be able to do for password recovery.
My current work laptop has no serial port but i have still kept one of my older work laptops and this is the one i always take if i am doing work on site.
Jon
Overall Rating: 4 (1 ratings)
Correct Answer
Jon Marshall Thu, 01/31/2008 - 15:57
Jon
guruprasadr Thu, 01/31/2008 - 23:36
HI,
In addition to Jon POST,
there are lot of other features that doesn't work with this convertor that i have experienced.
I normally use some Service Laptops to carry forward such work on-site.
Do RATE if HELPS
Best Regards,
Guru Prasad R
JoeMicro1 Tue, 02/05/2008 - 17:56
There are Pcmcia to Serial (DB9)cards out there with drivers. Works great. Break command works also
jamesawoodward Fri, 02/22/2008 - 15:59
I use a Radio Shack USB to Serial adapter. It works fine. Occasionally my laptop decides to assign it a different COM port, but that's visible through Device Manager. It does send Break commands as well.
Cheers.
Jim Woowdard
r.nockowitz Tue, 08/05/2008 - 03:26
What in the Brand/Model Number (or Radio Shack part number) of the USB-Serial adaptor supporting the Break sequence (Control-Break)?
