G703/G704
Jan 31st, 2008
controller E1 x/y/z
channel-group 0 timeslots 1
channel-group 1 timeslots 2
<repeat for all needed channels>
interface serial x/y/z:0
ip address ...
Kindly give me the complete sample configuration of about mention configuration commands.(G703/G704)
pcameron Thu, 01/31/2008 - 22:47
  • Cisco Employee,
Your question doesn't really make any sense. The config listed above is for framed operation, which is different to G703.
For unframed G703, you use this CLI snytax -
controller e1 0/0/0
channel-group 0 unframed
interface serial 0/0/0:0
ip address ...
This then makes the entire E1 a single channel group.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t1/feature/guide/dtg703.html
paolo bevilacqua Fri, 02/01/2008 - 01:00
  • Hall of Fame,
    Founding Member
Paul, Adnan is following up to an answer of mine. He needs info about channelized information.
Adnan, these are all the commands required. If the hardware is a vwic2, you also need "card type E1 ".
rgodden Fri, 02/01/2008 - 01:20
  • Bronze, 100 points or more
a g703 e1 card vwic2 doesnt need the card type command as it is only an e1 card it is not an e1/t1,hth
paolo bevilacqua Fri, 02/01/2008 - 01:33
  • Hall of Fame,
    Founding Member
On the other hand, the expensive vwic2 G.703 version is wasted for a channelized application, because it is really made for the unframed application that Paul mentioned before.
