AAA authentication error
Jan 31st, 2008
I have installed ACS 4.1 and is using a 3560 Switch,the only configuration on ACS is the "AAA Client" which is my Switch host name and its ip address. and the secrect key is the same as the AAA server sercet key.the comunication betweent he server and the client is just find,but when i try to connect my prompts me for the credentials but returns back with an wror messsage on ACS "Invalid message Athenticator in EAP request "....message type .."Bad Request from NAS". and i the error message on the switch is %Radius %_Dead:Radius Server port 1813,1812 is no responding.
Please find my switch configuration below :
aaa new-model
aaa authentication login default group radius
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
dot1x system-auth-control
no file verify auto
spanning-tree mode pvst
interface GigabitEthernet0/1
switchport mode access
dot1x pae authenticator
dot1x port-control auto
interface GigabitEthernet0/26
interface GigabitEthernet0/27
--More-- interface GigabitEthernet0/28
interface Vlan1
ip address
ip classless
ip http server
ip http secure-server
radius-server host auth-port 1812 acct-port 1813 key [email protected]
radius-server source-ports 1645-1646
line con 0
line vty 5 15
Switch#telnet 1812
Trying, 1812 ...
% Connection timed out; remote host not responding
Switch#telnet 1813
telnet 18132
Sending 5, 100-byte ICMP Echos to, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Kindly Suggest
ebreniz Wed, 02/06/2008 - 14:11
This message indicates that the system is unable to establish connection with any of the RADIUS servers. [dec] is the identification number of the RADIUS request packet. Check network connectivity.
datou1984923 Thu, 02/07/2008 - 04:31
you can change this command that radius-server host [email protected]
datou1984923 Thu, 02/07/2008 - 04:33
you can try this command that radius-server host key [email protected]
