rageurdreams Thu, 01/31/2008 - 23:34
Dear prasad,
thanks for ur document.
please send me related cisco link,
thanks
raj
guruprasadr Thu, 01/31/2008 - 23:37
  • Gold, 750 points or more
HI Raj,
I don't have any related cisco Link for this.
>> Let me check and keep you updated.
Best Regards,
Guru Prasad R
Danilo Dy Fri, 02/01/2008 - 07:05
  • Blue, 1500 points or more
Take note that FastEthernet (100Mbps) can be hardcoded to full-duplex but not all GigabitEthernet (1000Mbps) can be hardcoded to full-duplex some even hal-duplex. This is true in some network devices and server/OS (Unix) - I have once hardcoded a Cisco switch to 1000Mbps/full-duplex but I found out that the Unix server that connects to it can only hardcoded to 1000Mbps/half-duplex so I settle with 100Mbps/full-duplex both end of the wire since the maximum bandwidth utilization is around 40Mbps. Packeteer products doesn't allow you hardcoding GE interfaces.
Monitor your bandwidth overtime, if you are not hitting 100Mbps, settle with 100Mbps/full-duplex as the performance is many times better than 1000Mbps/half-duplex. If you need more than 100Mbps, it is best to set GE to auto-speed/auto-duplex both end of the wire, just make sure that the cable is correct and in good quality to a avoid flapping.
Dandy
