Ios Compression
Jan 31st, 2008
Hi, i am looking for a way to do software data compression through cisco IOS. while searching i went through a white paper that discussed different compression techniques like per-interface compression, tcp/ip header comp etc, but i am not able to find any configuration for data compression through software, so is it possible to do so, kindly keep these facts in mind
1) i am not using VoiP i just want to compress my data payload
2) most of the routers are 1841, but we also have 2811, 3845, 3640
So is there any way to do software compression ??
illusion_rox Fri, 02/01/2008 - 20:13
hi, i have seen the link but it has shown example of on mppc, we are using DSL mostly in our network and ppp is not there, so far what i have learned that cisco supports
stacker, predictor and mppc, but i havent found configuration for predictor so if any1 can help me out ?
