Migrating Site-Site VPN
Feb 1st, 2008
I currently have a site-site VPN (VPN1) betwween a Cisco Pix 506E and an ASA 5510 in HK and Leeds respectively. I need to move the IPsec tunnel to another internet gateway (10 Mb) in Leeds to which is connected a Cisco Pix 506E. To make any changes to the PIX 506E in HK, I will need to connect to it accross the current VPN tunnel (VPN1). I run the risk of loosing connectivity to HK if changes are made to the VPN1 configuration in HK. How do I work around this ? Can I create a second VPN tunnel (VPN2) and then shutdown VPN1 when the new VPN is up and running?
Jon Marshall Fri, 02/01/2008 - 00:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes, that is exactly what you should do. Are you comfortable with doing it on the HK device ?
Jon
dasgill Fri, 02/01/2008 - 02:51
Dear Jon,
I am comfortable creating the tunnel on the HK device. I am assuming everything should be fine as long as the isakmp poliy number, transformset and crytomap names are different on for the 2 tunnel configurations on the HK device.
Jon Marshall Fri, 02/01/2008 - 02:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Isakmp policy number is not tied to the peer ip address so you can use the same one for both connections, unless you are actually changing something within the ISAKMP policy.
The same goes for the transform-set.
The crypto map name will not be different because you can only apply one crypto map name to an interface. Just use a different index number. So if your existing crypto map looks like
crypto map vpnset 1 ipsec-isakmp
crypto map vpnset 1 set peer x.x.x.x
crypto map vpnset 1 match address "acl"
etc..
for the new VPN
crypto map vpnset 2 ipsec-isakmp
crypto map vpnset 2 set peer x.x.x.x
etc...
assuming of course you aren't already using index number 2.
Jon
dasgill Fri, 02/01/2008 - 03:49
Dear Jon,
Thank you very much. As far as isakmp is concerned I will need to add a different key for the second tunnel:
isakmp key ***** address netmask 255.255.255.255.
Cryto map: change index number.
How do I take tumnnel VPN1 down once VPN2 is up and running.
Jon Marshall Fri, 02/01/2008 - 04:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes you will need a different isakmp key.
Do you mean take it down or make sure it can't be used again ?
Take down
clear crypto ipsec sa peer x.x.x.x
To ensure it can't be used again remove config or at very least the isakmp key.
Jon
dasgill Mon, 02/04/2008 - 07:17
I have configured both firewalls as advised by Jon but I am geeting some errors when attempting to pass interesting traffic. I attach the errors and the configs for the 2 PIx's below:
Feb 04 15:06:42 [IKEv1]: QM FSM error (P2 struct &0x1b24150, mess id 0x47595d7)!
Feb 04 15:06:42 [IKEv1]: Group = 192.168.0.1, IP = 192.168.0.1, Removing peer from correlator table failed, no match!
Feb 04 15:06:42 [IKEv1]: QM FSM error (P2 struct &0x1b24860, mess id 0x9cafcd4d)!
sh Feb 04 15:06:47 [IKEv1]: QM FSM error (P2 struct &0x1d085d0, mess id 0x458d4091)!
Feb 04 15:06:47 [IKEv1]: Group = 192.168.0.1, IP = 192.168.0.1, Removing peer from correlator table failed, no match!
sh crypto isakmp sa
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 192.168.0.1
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
PIX 1 (192.168.0.3)
crypto ipsec transform-set ford esp-des esp-md5-hmac
crypto map VPNHK 2 match address outside_crypto_acl
crypto map VPNHK 2 set peer 192.168.0.1
crypto map VPNHK 2 set transform-set ford
crypto map VPNHK interface outside
isakmp identity address
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 1000
isakmp am-disable
console timeout 0
tunnel-group 192.168.0.1 type ipsec-l2l
tunnel-group 192.168.0.1 ipsec-attributes
pre-shared-key ev0lut10n
PIX 2 (192.168.0.1)
crypto ipsec transform-set chevvie esp-des esp-md5-hmac
crypto map transam 1 ipsec-isakmp
crypto map transam 1 match address 101
crypto map transam 1 set peer 192.168.0.2
crypto map transam 1 set transform-set chevvie
crypto map transam 2 ipsec-isakmp
crypto map transam 2 match address 101
crypto map transam 2 set peer 192.168.0.3
crypto map transam 2 set transform-set chevvie
crypto map transam interface outside
isakmp key ichabod address 192.168.0.2 netmask 255.255.255.255
isakmp key ev0lut10n address 192.168.0.3 netmask 255.255.255.255
