Interface status waiting in Pix
Feb 1st, 2008
While executing sh fail command..one of the pix interface status shows as waiting..
Pix# sh fail
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 5 seconds
failover replication http
Last Failover at: 22:44:36 UTC Thu Jan 31 2008
This host: Secondary - Active
Active time: 58260 (sec)
Interface outside (172.x.x.194): Normal
Interface inside (172.x.x.1): Normal
Interface ab (172.x.x.1): Normal
Interface ext (172.x.x.9): Normal
Interface isp (172.x.x.17): Normal (Waiting)
Interface failover (192.x.x.1): Normal
Other host: Primary - Standby
Active time: 910 (sec)
Interface outside (172.x.x.195): Normal
Interface inside (172.x.x.5): Normal
Interface ab (172.x.x.3): Normal
Interface ext (172.x.x.11): Normal
Interface isp (172.x.x.19): Normal
Interface failover (192.x.x.2): Normal
All the firewall ports are connected to Cat6513 switch..to solve this issue i have plugged out and in once in both the sides..but status remails the same.Kindly help to resolve the issue/.
m.sir Fri, 02/01/2008 - 01:33
Each PIX remains in a "waiting" mode until it hears 30 seconds worth of "hello" packets from the other unit.
Check this
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#Moniter
Cisco recommends turn off channel, trunk , turn on portfast
if you are running catos you can do it with command
set port x/x host
if IOS
conf t
interface x/x
switchport mode acces
switchport spantree portfast
M.
hope that helps rate if it does
jojuarez Sun, 02/03/2008 - 21:50
The "normal (waiting)" status is usually a L2 issue. You can double-check the configuration and/or cables on the switch
