Redundant Site to Site VPN Pix/ASA
Answered Question
Feb 1st, 2008
Hi All,
I have a site which has two peer endpoints and wants one of them to be redundant. I know it's possible to configure on the crypto map more than one peer.
Is there a configuration feature like dpd available on the pix/asa? The version running on the pix is 7.2.3.
TIA
Jack
Correct Answer by acomiskey about 8 years 11 months ago
See here under usage guidelines...
http://cisco.com/en/US/docs/security/asa/asa72/command/reference/c5_72.html#wp2066090
connection type needs to be originate-only as well, which means the far end must be answer-only.
I also don't think you need to create separate tunnel groups, but I could be wrong.
Overall Rating: 5 (1 ratings)
jackwikinski Fri, 02/01/2008 - 08:50
Thanks for your answer.
In essence my config should look someting like this:
crypto map match address 101
crypto map pix set peer peer one
crypto map pix set peer peer two
crypto map set transform-set myset
tunnel-group peer 1 type ipsec-l2l
tunnel-group peer 1 ipsec-attributes
isakmp keepalive 10 2
tunnel-group peer 2 type ipsec-l2l
tunnel-group peer 2 type ipsec-attributes
Thanks.
Jack.
