USB boot help on 1811
Feb 1st, 2008
I have 1811 , which yesterday had a problem with the CF. I want to use my USB support to boot from. I am reading for two days and really i can't find really useful info on cisco.com I think my RMMON doesn't support usb , becasue of the rmmon>dev command i issue and it didn't show mi my usbflash. Please point me in the right direction my router is :
1811
rommon 6 > showmon
ReadOnly ROMMON version is:
System Bootstrap, Version 12.3(8r)YH3, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Upgrade ROMMON version is:
System Bootstrap, Version 12.3(8r)YH5, RELEASE SOFTWARE (fc1)
Upgrade ROMMON currently running
Upgrade ROMMON is selected for next boot
i am aware of all usb FS and size restrictions , i've also format my usb for the correct C filesytem for the 1811 i believe the problem is in the RMMON features and version.
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Fri, 02/01/2008 - 02:20
  • Hall of Fame,
    Founding Member
for the 1841, the download page states that certain rommon revisions have boot from usb capabilities.
For the 1811, the latest is C1800_RM2.srec.123-8r.YH12 but boot from usb is not mentioned.
So I guess you can only try to see if the latest does it.
Note all of the above requires registered customer (support contract).
ivan.grancharov Sat, 02/02/2008 - 06:15
Thanks p.bevilacqua ,
I will download the newest and check it :)
There is no sense that my router have usb support , but i cannot use it as a alternative boot option. I hope i will boot 1811 after ROMMON upgrade :)
Thanks again and Cheers :)
smitty6504 Fri, 02/01/2008 - 06:23
Ivan,
You are correct about the ROMMON issue. I found the same issue with a 3845 router we had. I had to update the ROMMON to 12.4 to support the boot from USB option.
ivan.grancharov Sat, 02/02/2008 - 06:12
Thanks smitty , you confirmed that i'm in the right direction thanks again and cheers :)
atif-siddiqui Fri, 05/16/2008 - 18:11
Do you know how we can upgrade ROMMON version on 3845 using USB?
