Syntax for ACS Proxy Ditribution prefix
Feb 1st, 2008
Can someone tell me what syntax I must use to successfully create a RADIUS Proxy prefix ?
I have got my own domain (mychild.mydomain.local).
All non-local users must be forwarded to another RADIUS server on the internet.
In ACS 3.3.3 I created a character string ".mydomain.local" as a suffix.
When I log in with a user in the domain "[email protected]" everything works ok.
Now I want to use windows logon. There the format is mychild\testuser. Right now I need to create a prefix I asume..
What syntax do I need ?
.mychild.mydomain.local is not working
.mydomain.local is not working.
Gr.
Remco
remco.gussen Thu, 02/07/2008 - 10:10
Thank you for your help.
The problem is the Windows login (Gina) when pc is started.. You must / can enter the credentials as follow: username, password, domain.
I thought that the ACS sees this as domain\username. In the log you can see that.
If the default Proxy method points to the local RADIUS server, everything is ok.
But now I created a character string of "domain\" as prefix that points to local RADIUS server. Default points to internet RADIUS server.
Login in Windows(Gina) does not work anymore.
It works only when you enter in the username box: domain\username en the password.
Then it is ok.
Why does it not work when entering username, password and domain field ?
