debug ip packet not working
Hi!
I'm trying to debug some traffic on my network by using access-lists and the command debug ip packet detail <acl>, but it just won't show any debugging. It is set up properly according to this link: http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#ts
But I DO get some messages:
pak 19EDD48 consumed in input feature , packet consumed, Access List(8), rtype 0, forus FALSE, sendself FALSE, mtu 0
pak 1A35F08 consumed in input feature , packet consumed, Access List(8), rtype 0, forus FALSE, sendself FALSE, mtu 0
pak 19F99C8 consumed in input feature , packet consumed, Access List(8),rtype 0, forus FALSE, sendself FALSE, mtu 0
Can it be because I use VLAN Interfaces instead of physical interfaces?
I have tried this on several C3550's with same result.
Any tips?
Thanks.
Richard Burts Fri, 02/01/2008 - 03:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Oystein
When people say that debug is not working, my first reaction is to ask to make sure that they have terminal monitor enabled or that logging buffer is enabled with severity level of debug. But if you are getting some messages then this is not the issue.
My other suggestion is that for debug to report the traffic the CPU must process the packet. Traffic that is forwarded in hardware or in interrupt mode like fast switching will not hit debug. So you may need to assure that the packets are being process switched.
Rick
Richard Burts Wed, 02/06/2008 - 21:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Oystein
I have read (and re-read) your post, and I do not see where you have disabled fast switching/CEF switching and forced process switching of packets. Perhaps you can clarify that for me.
Rick
