IPS Clock in the event viewer
josephium
i have set up the clock on my AIP-SSM 20, if i do a show clock it will display the correct time, but still in the event viewer the sensor UTC time is different, how can i have the correct time in the event viewer ? i have realized also that if i want to try something and change the time , the sensor has to reset!?
rolandshum
I've noticed this particular issue myself. I haven't found a fix for it yet.
so is this a bug ?
No its not the bug, the event viewer on the sensor will only show UTC time, I called TAC and they said the same thing. If you install IEV and click on the alert and look for details you will see the local time.
I wish it should show the local time in the IPS sensor event viewer.
joe.andrade
I posted a similar issue on 1/23/08 but did not receive much support. Have you had any good results? It's definately a problem. Can't generate any reports from IEV when they are based on data from preceding hours versus the data received is considered 8 hours in the future (PST -8).
