Inter VLAN routing in 3750 switch
Answered Question
Feb 1st, 2008
How can enable Inter VLAN routing in Cisco 3750 Switch without router?
Correct Answer by m.sir about 9 years 1 month ago
3750 is L3 switch so its no big problem..
You need to ensure ip routing is enabled with command
ip routing
Create vlans between you want to route
interface Vlan10
This IP address would be the default gateway for users in VLAN 10
interface Vlan20
ip address 192.168.2.1 255.255.255.0
This IP address would be the default gateway for users in VLAN 20
Now users in VLAN 10 can communicate with users in VLAN 20
Check this link for me info
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00801cc828.shtml
M.
Hope that helps rate if it does
Overall Rating: 4.8 (3 ratings)
Jon Marshall Fri, 02/01/2008 - 03:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
1) Turn on ip routing ie.
3750(conf t)# ip routing
2) For each vlan that you have on the switch create a L3 vlan interface ie.
vlan 10
192.168.5.1 255.255.255.0
no shut
vlan 11
192.168.6.1 255.255.255.0
no shut
etc..
3) For clients in vlan 10 set the default-gateway to be 192.168.5.1
For clients in vlan 11 set the default-gateway to be 192.168.6.1
etc..
4) If all the inter-vlan routing is done on the 3750 you do not need a routing protocol as the 3750 will automatically route between connected interfaces - provided you have done step 1.
Jon
Correct Answer
m.sir Fri, 02/01/2008 - 03:49
  • Gold, 750 points or more
ip routing
interface Vlan10
interface Vlan20
M.
