02-01-2008 04:11 AM - edited 03-15-2019 08:34 AM
Hi Guys, I need some help if anyone can, my company wants to re-route our mobile numbers through another company so pro-ceding each mobile number dialed from within the company they want to add for instance a four digit number "1624" does any one know what i would have to write in the gateway config for this to happen?
Any help much appreciated.
Dan
Solved! Go to Solution.
02-04-2008 04:30 AM
Ok then try..
rule 9 /^7/ /9162407/
So 07788 9912345 becomes 91624077889912345
02-01-2008 04:14 AM
Do you have CM? If so, do you use h.323 or MGCP ?
And, how do you identify these mobile numbers ?
02-01-2008 04:22 AM
Yes we have CM, yes we use h.323
all mobile numbers start with 07.
our dial plan looks like this on the gateway
voice translation-rule 90
rule 1 /^....$/ /69&/
rule 3 /^1/ /901/
rule 4 /^2/ /902/
rule 5 /^3/ /903/
rule 6 /^4/ /904/
rule 7 /^5/ /905/
rule 8 /^6/ /906/
rule 9 /^7/ /907/
rule 11 /^9/ /909/
rule 12 /^0/ /90/
02-01-2008 02:37 PM
you can also do this in CCM at two levels
under the route pattern or under the route list
both have a prefix option in which before the call reaches the gateway you can send the digits preceding what the user dialed
for this you would need to create a set of specific route patterns to match only the mobile calls
02-04-2008 03:45 AM
To add digits to the end of the mobile number change rule 9 for the following
rule 9 /^7\(.*\)$/ /907\11624/
So 07788 9912345 becomes 90778899123451624
I think that is what you are after, if not let me know.
If this post helps, please rate.
Dave
02-04-2008 04:14 AM
Thanks for the help Dave thats absolutely brill, other then the fact i would like it to proceed the mobile number and not go at the end? :) thanks alot :)
02-04-2008 04:30 AM
Ok then try..
02-04-2008 04:46 AM
The GWGK cisco book has this info in depth if anyone is wondering.
