getting gig interface down
Answered Question
Feb 1st, 2008
GigabitEthernet0/3 is up, line protocol is down is error i ma getting what hsould i check and how to rectify it
Correct Answer by Richard Burts about 9 years 3 months ago
Amit
Interface up line protocol down sometimes means that there is not anything plugged into the interface.
I believe that it can also result from a speed mismatch. So check the switch interface and verify speed and duplex settings. Then verify on the device connected to the port what its speed and duplex settings are. Make sure that speed and duplex settings are the same.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Fri, 02/01/2008 - 05:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Amit
Rick
Richard Burts Fri, 02/01/2008 - 08:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Amit
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will read about the successful resolution of the issue.
The forum is an excellent place to learn more about Cisco networking. I encourage you to continue your participation in the forum.
Rick
