NAC Appliance web problem
Feb 1st, 2008
I have installed 2 CAMs and 2 CASs with version 4.1.2.1. 1 CAM and 1 CAS runs smoothly and I can access the web administration. But some thing wrong with the other CAM and CAS. I can't access web admin at all. No problem with connection, but the httpd service doesnot run. I try to restart perfigo service, but console shows error.
Badness in local_bh_enable at kernel/softirq.c:140
[<c011e748>] local_bh_enable+0x68/0x80
[<f8aaa2ed>] send_command+0x7d/0x90 [pkp_drv]
[<f8aa96fb>] pkp_boot_init+0x2bb/0x320 [pkp_drv]
[<f8aa9900>] do_init+0x1a0/0x2c0 [pkp_drv]
[<f8aa66d8>] do_soft_reset+0x88/0xb0 [pkp_drv]
[<f8aa5ebf>] handle_soft_reset+0xf/0x20 [pkp_drv]
[<f8aa9ee7>] cavium_interrupt_handler+0xe7/0x140 [pkp_drv]
[<f8aa4d17>] linux_layer_isr+0x7/0x10 [pkp_drv]
[<c01354f3>] handle_IRQ_event+0x33/0x70
[<c01355d7>] __do_IRQ+0xa7/0x110
[<c0104769>] do_IRQ+0x19/0x30
[<c0102fde>] common_interrupt+0x1a/0x20
[<c0113c5a>] hpet_readl+0xa/0x10
[<c010f43c>] delay_hpet+0x2c/0x40
[<c01cde99>] __delay+0x9/0x10
[<f8aa6f5b>] check_completion+0x2b/0x50 [pkp_drv]
[<f8aa9709>] pkp_boot_init+0x2c9/0x320 [pkp_drv]
[<f8aabfe9>] get_buffer+0x9/0xb0 [pkp_drv]
[<f8aa495b>] n1_ioctl+0x35b/0x6f0 [pkp_drv]
[<c0161386>] open_namei+0x96/0x5a0
[<f8aa4600>] n1_ioctl+0x0/0x6f0 [pkp_drv]
[<c0164229>] do_ioctl+0x69/0x70
[<c01643ec>] vfs_ioctl+0x5c/0x1f0
[<c01645bd>] sys_ioctl+0x3d/0x70
[<c0102e6f>] syscall_call+0x7/0xb
Later, I check linux system log at /var/log/messages. it says:
Feb 1 11:56:38 SG-CAM-01 kernel: Uhhuh. NMI received. Dazed and confused, but tt
rying to continue
Feb 1 11:56:38 SG-CAM-01 kernel: You probably have a hardware problem with yourr
RAM chips
Feb 1 11:56:38 SG-CAM-01 kernel: ACPI: PCI interrupt 0000:10:01.0[A] -> GSI 5 ((
level, low) -> IRQ 5
Feb 1 11:56:38 SG-CAM-01 kernel: Badness in local_bh_enable at kernel/softirq.cc
:140
Feb 1 11:56:38 SG-CAM-01 kernel: [<c011e748>] local_bh_enable+0x68/0x80
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aaa2ed>] send_command+0x7d/0x90 [pkp_drv]
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa96fb>] pkp_boot_init+0x2bb/0x320 [pkp_dd
rv]
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa9900>] do_init+0x1a0/0x2c0 [pkp_drv]
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa66d8>] do_soft_reset+0x88/0xb0 [pkp_drvv
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa5ebf>] handle_soft_reset+0xf/0x20 [pkp__
drv]
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa9ee7>] cavium_interrupt_handler+0xe7/0xx
140 [pkp_drv]
Feb 1 11:56:38 SG-CAM-01 kernel: [<f8aa4d17>] linux_layer_isr+0x7/0x10 [pkp_drr
v]
Feb 1 11:56:38 SG-CAM-01 kernel: [<c01354f3>] handle_IRQ_event+0x33/0x70
Feb 1 11:56:38 SG-CAM-01 kernel: [<c01355d7>] __do_IRQ+0xa7/0x110
Feb 1 11:56:38 SG-CAM-01 kernel: [<c0104769>] do_IRQ+0x19/0x30
Feb 1 11:56:38 SG-CAM-01 kernel: [<c0102fde>] common_interrupt+0x1a/0x20
Feb 1 11:56:38 SG-CAM-01 kernel: [<c0113c5a>] hpet_readl+0xa/0x10
Feb 1 11:56:38 SG-CAM-01 kernel: [<c010f43c>] delay_hpet+0x2c/0x40
Feb 1 11:56:38 SG-CAM-01 kernel: [<c01cde99>] __delay+0x9/0x10
Feb 1 11:56:39 SG-CAM-01 kernel: [<f8aa6f5b>] check_completion+0x2b/0x50 [pkp__
drv]
Feb 1 11:56:39 SG-CAM-01 kernel: [<f8aa9709>] pkp_boot_init+0x2c9/0x320 [pkp_dd
rv]
Feb 1 11:56:39 SG-CAM-01 kernel: [<f8aa9900>] do_init+0x1a0/0x2c0 [pkp_drv]
Feb 1 11:56:39 SG-CAM-01 kernel: [<f8aabfe9>] get_buffer+0x9/0xb0 [pkp_drv]
Feb 1 11:56:39 SG-CAM-01 kernel: [<f8aa495b>] n1_ioctl+0x35b/0x6f0 [pkp_drv]
Is it true, a hardware problem? I have tried to change the memory, but error is still the same. Any idea with this?
Regards.
0600648902 Sun, 02/03/2008 - 21:07
Hi All,
Any idea with this problem ?
Thanks in advance.
