catalyst 4500 switch freezes
Hi All
I have a catalyst 4500 switch on my network, fairly new, its actually not up to a year old and its running on IOS version 12.2(31)SG.
Couple of days ago, it just frooze out, and the whole network grounded to a halt, i could not console into or get into it in any other way at all
I eventually had to reboot it to be able to access it and resolve the problem.
4500s are supoosed to be rugged, does anybody has a clue/solution?
Collin Clark Fri, 02/01/2008 - 06:54
  • Purple, 4500 points or more
look in the flash (dir) and see if there is a crash dump. If there is open a TAC case and submit it. They'll be able to tell you whats wrong.
glen.grant Fri, 02/01/2008 - 20:00
Once you reboot you lose all the logg info so it would just be speculation at this point, could have been someone plugged in something they shouldn't and caused a bridging loop and this could cause it to drive the cpu to saturation so it looked like it hung , just speculation though .
