EIGRP Event Message
Feb 1st, 2008
Is there a reference for EIGRP event messages and their meaning?
Event information for AS 200:
1 22:18:53.390 Poison squashed: 192.168.125.0/25 reverse
2 22:18:53.390 Poison squashed: 10.255.255.28/30 reverse
3 22:18:53.390 Poison squashed: 192.168.125.252/30 reverse
4 22:18:53.158 Rcv EOT update src/seq: 192.168.62.10 14702813
5 22:18:50.382 Metric set: 0.0.0.0/0 4294967295
6 22:18:50.382 Poison squashed: 0.0.0.0/0 metric chg
7 22:18:50.382 Find FS: 0.0.0.0/0 4294967295
8 22:18:50.382 Rcv update met/succmet: 16002560 28160
9 22:18:50.382 Rcv update dest/nh: 0.0.0.0/0 192.168.62.10
10 22:18:50.382 Metric set: 0.0.0.0/0 4294967295
11 22:18:50.146 Got peer INIT: 192.168.62.10 Tunnel10
12 22:18:46.098 Peer down end, handle: 0
13 22:18:46.098 NDB delete: 0.0.0.0/0 1
14 22:18:46.098 RDB delete: 0.0.0.0/0 192.168.62.10
15 22:18:46.098 Peer down: 192.168.62.10 Tunnel10
Overall Rating: 3 (1 ratings)
jsivulka Thu, 02/07/2008 - 07:18
Yes there is a reference for EIGRP event messages.Show ip eigrp event log that 'should' show the problem occure in devices.
The show [ip][ipx][appletalk] eigrp events command will cause a spurious memory access error and invalidate the content of the Enhanced Interior Gateway Routing Protocol (EIGRP) event log. This defect is logged in Cisco bug ID CSCdk33475
