crypto ipsec gre tunels droped
Feb 1st, 2008
From time to time lots of tunnels drop down due to:
Feb 1 15:10:05 EET: CRYPTO_ENGINE: crypto_pak_coalesce: could not get buffer for new pak. requested size 24
Feb 1 15:10:05 EET: CRYPTO_ENGINE: crypto_pak_coalesce: could not get buffer for new pak. requested size 90
Can somebody help me ?
#sho crypto eli
Hardware Encryption : ACTIVE
Number of hardware crypto engines = 1
CryptoEngine VAM2+:1 details: state = Active
Capability : IPPCP, DES, 3DES, AES, RSA, IPv6
IKE-Session : 423 active, 5120 max, 0 failed
DH : 227 active, 5120 max, 0 failed
IPSec-Session : 746 active, 10230 max, 0 failed
Router:
Cisco 7206VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memory.
sadbulali Thu, 02/07/2008 - 09:28
  • Bronze, 100 points or more
To configure Generic Routing Encapsulation (GRE) over an IPSec tunnel between two routers, perform these steps:
Create a tunnel interface (the IP address of tunnel interface on both routers must be in the same subnet), and configure a tunnel source and tunnel destination under tunnel interface configuration, as shown:
interface Tunnel0
ip address 192.168.16.1 255.255.255.0
tunnel source
tunnel destination
Configure isakmp policies, as shown:
crypto isakmp policy 1
authentication pre-share
Configure pre share keys, as shown:
crypto isakmp key cisco123 address (Remote outside interface IP with 32 bit subnet mask)
Configure transform set, as shown:
crypto ipsec transform-set strong esp-3des esp-md5-hmac
Creat crypto ACI that permits GRE traffic from the outside interface of the local router to the outside interface of the remote router, as shown:
access-list 120 permit gre host (local outside interface ip) host (Remote outside interface IP)
Configure crypto map and bind transform set and crypto Access Control List (ACL) to crypto map. Define peer IP address under crypto map, as shown:
crypto map vpn 10 ipsec-isakmp
set peer
set transform-set strong
match address 120
Bind crypto map to the physical (outside) interface if you are running Cisco IOS? Software Release 12.2.15 or later. If not, then the crypto map must be applied to the tunnel interface as well as the physical interace, as shown:
interface Ethernet0/0
ip address
half-duplex
crypto map vpn
Configure Network Address Traslation (NAT) bypass if needed, as shown:
access-list 175 deny ip (local private network) (subnet mask) (remote private network) (subnet mask)
access-list 175 permit ip (local private network) (subnet mask) any
route-map nonat permit 10
match ip address 175
exit
ip nat inside source route-map nonat interface (outside interface name) overload
