strange spanning-tree vlan output
Hi All
I have a problem with my cisco3750 switch..
If I issue sh spanning-tree summary I get
(look attach)
In particular for vlan 242 and 243
VLAN0242 - 245 - 249 - 253 -1872756559 1012957184
VLAN0243 - 245 - 249 - 253 -1872756559 1012957184
if I issue sh spanning-tree vlan 242 or 243 it gives
sw-com1-be#sh spanning-tree vlan 242
VLAN0242
Spanning tree enabled protocol ieee
Root ID Priority 4338
Address 0005.dd27.3440
Cost 4
Port 1000 (StackPort1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 45298 (priority 45056 sys-id-ext 242)
Address 0019.3027.f580
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa1/0/9 Desg FWD 19 128.11 P2p
As you see no root port in the output... but the infrastructure works well machine in the same vlan (242 or 243) cona communicate...
What happens ???
Giuseppe
Edison Ortiz Fri, 02/01/2008 - 08:25
  • Hall of Fame,
    Founding Member
Please attach the whole show spanning-tree output, not just the summary.
__
Edison.
Edison Ortiz Fri, 02/01/2008 - 09:19
  • Hall of Fame,
    Founding Member
I never seen the stackport listed in the spanning-tree information.
Are you having multiple 3750 switches connected using the stackwise cable and you also used the front switchports for inter-switch connection?
Can you post the output from typing show switch and show cdp neighbor detail
