Tunnel Issues
Feb 1st, 2008
here's a brief description , we have 2 routers that were working for at least 2 years sudenly a couple of days ago we got this message and the tunnel didnt pass any traffic.
%CRYPTO-6-IKMP_CRYPT_FAILURE: IKE (connection id 268435457) unable to decrypt (w/RSA private key) packet
we removed the crypto map and everything is working now , the only config changed because a company requeriment was a line , one of the routers used to have no ip domain lookup and the change was setting to ip domain lookup nothing else was done , any ideas was caused the failure???
f.aoun Fri, 02/01/2008 - 06:46
check if isakmp identity is hostname not address.
eperezrdz Fri, 02/01/2008 - 06:56
Thanks for the reply ¡ , this is before:
no ip domain-lookup
ip domain-name xxxxxxxxx.com
crypto isakmp policy 10
encr 3des
authentication rsa-encr
group 2
crypto ipsec transform-set xxxx-trans ah-sha-hmac esp-3des
crypto ipsec df-bit clear
crypto map xxxxxxx 10 ipsec-isakmp
set peer 1x.xxx.xx.x
set security-association level per-host
set transform-set xxxx-trans
match address xxxxxxxxxx
crypto key pubkey-chain rsa
addressed-key xx.xxx.xxx.xxx encryption
address 1x.xxx.xx.x
This is afeter:
ip domain-name xxxxx.com
encr 3des
group 2
crypto map xxxxxx 10 ipsec-isakmp
set peer xx.xxx.xx.x set security-association level per-host
set transform-set xxxxx-trans
match address xxxxx
addressed-key xx.xxx.xxx.xx encryption
address xx.xxx.x.x
key-string
Any more toughts?? how to check what you suggest me??
