Geographic BGP Design
Feb 1st, 2008
I am trying to develop a conceptual design. A company has at least two data centers with each being mutihomed to the Internet through different providers using BGP in a active/backup role. If the company wants to go active/active to the Internet how would they backhaul the iBGP traffic between the set of CE routers? The only ways I could think of would be to set up WAN links on the CE routers, cost prohibitive or the other would be to create a tunnel between the sets of CE routers. Does this make sense or are there other potential solutions?
Brett
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Fri, 02/01/2008 - 07:07
  • Hall of Fame,
    Founding Member
As you said if you set GRE tunneling (point-to-point or multipoit) between your CE routers, even across different ISP, iBGP will work nicely on it.
brettjohnson444 Fri, 02/01/2008 - 07:34
Thank you for the response. Running it through the internal network would seem like the better solution provided you had WAN redundancy and sufficient bandwidth to the other site, if not running it accross the Internet would seem best. Do you agree?
Brett
paolo bevilacqua Fri, 02/01/2008 - 08:02
  • Hall of Fame,
    Founding Member
Yes Brett, it's exactly so.
Please remember to rate useful posts using the scrollbox below!
Danilo Dy Fri, 02/01/2008 - 07:09
  • Blue, 1500 points or more
The ideal is P2P WAN link between two sites, however you can also setup IP GRE Tunnel between two site across internet.
The most important is to avoid split-BGP when iBGP connection lost between two sites.
Dandy
