ASA 5505 upgrade ASDM and ASA software
ryankrupp
I have recently tried a upgrade from asa722.bin to asa802-k8.bin and asdm502.bin to asdm6.2.bin. I had renamed the old asa and asdm images. When try to launch the ASDM Manager i get an error 'your asa image has a version number 8.0(2) which is not supported by ASDM5.2' and it kicks me out. I tried to do a reload of default config and it doesn't reload the default config, it just says "loading cached software". Is there away of getting to my ASA 5505 by ASDM launch manager?
ASA running 8.0.2.. we need to use asdm 6.0.2 .. pls upload asdm-602.bin file on flash .old extension file will not work
then commands
no asdm image flash:/asdm-522.bin
asdm image flash:/asdm-602.bin
8 Replies 8
srue
Level 7
Level 7
enter this command:
asdm image disk0:/asdm6.2.bin
it gives me error ACSII command
thanks
after i ran asdm image command, i'm still getting the same error and i can't get into the ASDM manager. Any help would be appreciated.
this is what i have on my disk0:
Pls do "show version" check if firewall is running on 7.2.2 then we need to use asdm 522 image which in flash.
Pls give a command in configuration prompt
write memory
if possible reboot
If you IOS in running 8.0.2 then we need to use asdm 6.0.2 .. pls upload asdm-602.bin file on flash .old file will not work
then commands
* pls check http access is enable on firewall .. else give command
http server enable
http 0 0 inside
Hope this helps.
Pls rate if this works so that others can take benefit of this forum
Thanks for the reply. Here's the show version attachment. Hopefully you can help.
Thanks Again.
then commands
Thanks, i'll give that a try and let you know.
