Translation rule for incoming calls
Answered Question
Feb 1st, 2008
Hi to all,
problaby my question is stupid, but I don't know to resolve.
I have a CME on 2811, for each incoming calls it strip the first left zero digit of number (DID).
Can I with translation rule put this zero? Or better can I prevent any digit stripping of incoming calls?
Augusto
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
Augusto, CME is not stripping anything, it's the normal way of TI to present numbers this way, as they use ISND type/plan.
The translation-rule below, will prefix 0 for fixed number, 00 for international, nothing for cellulars:
voice translation-profile addzero
translate calling 10
voice translation-rule 10
rule 1 // /0/ type national national
rule 2 // /00/ type international international
int bri x/y
trunk-group bri
trunk group bri
translation-profile incoming addzero
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 02/01/2008 - 07:38
int bri x/y
trunk-group bri
trunk group bri
a.crippa Fri, 02/01/2008 - 07:49
Hi Paolo,
you understand exactly my problem (yes I know it's TI issue), thank now it's OK.
Augusto.
