02-01-2008 08:18 AM - edited 03-05-2019 08:53 PM
I have a Cisco 4500 Switch as core switch where all the users will be conecting to and there will be two 3845 routers facing a datacenter.
I need to have three VLANs:
VLAN1 for managemnet
VLAN2 internal Office
VLAN3 External Office
and have this switch talk to these routers. Then I need to setup (all static) HSRP between the two routers for redundancy.
I would appreciate if you guys can help me with the configuration of these VLANs. all on the switch? do I need subinterfaces? I have enough physical ether interfaces on the routers.
since it is only pone switch as core and everthing else, collapse, then I assume i don't need subInterfaces on the router. I am confused on how to defined the trunck or truncks in this case.
Your input is highly apprecitaed.
Mike
Solved! Go to Solution.
02-01-2008 10:06 AM
Mike
Well you can use the static routes as outlined before. Assuming that your 3845 routers would have routes for the remote sites you could just add a default route on your 4500 switch one for each 3845 router ie.
ip route 0.0.0.0 0.0.0.0 "3845_1 interface connected to 4500"
ip route 0.0.0.0 0.0.0.0 "3845_2 interface connected to 4500"
Or as said before you can use a dynamic routing protocol between your 4500 and 3845 routers.
The links from the 4500 to the 3845's are not trunk links. They are not L2 links at all. They should be configured as L3 P2P links - see previous post for configuration details.
Jon
02-01-2008 07:37 PM
If you are doing the routing on the 4500's then no the link will not be a trunk link just a routed link . On the 4500 link interface just type no switchport which makes that a routed port and add your address to the interface . The link would only be a trunk if you choose to do all your routing on the 3845's.
02-01-2008 08:26 AM
Hi Mike
It sounds like you want to do the routing for the vlans on the 3845 routers - is that the case. If so then all you need to do on the 4500 is
1) Create the 3 vlans at layer 2 ie.
4500(config)# vlan 2
4500(config-vlan)# name Internal
etc..
2) If you have enough interfaces on the 3825 routers you do not need to use trunk links you can just allocate 3 ports on each 3825 and put one in each vlan. You then just connect them up to the switch and allocate the switchports into the relevant vlans ie.
4500(config-if)# switchport access vlan 2
etc..
You don't say which version of 4500 it is ie. if it were a 4507R then it could have redundant supervisors i which case it would make sense to use that to do the inter-vlan routing.
Jon
02-01-2008 08:43 AM
Hi Jon,
sorry, I must have provided full info.
I have 4510R SUP 6 and 3845 routers with 4 Ether interface.
I need the VLANs on th eswitch and then send the traffic over to the routers. Ther might be a Firewall in between as weell not i am not sure at this time.
I would appreciate if you could elaborate a little on the actual configuration. I do understand the concept as you explianed but its been a while!!?
Thx,
Mike
02-01-2008 08:47 AM
Mike
Does your 4510 have dual sups ?.
All the L3 inter-vlan routing can be done either
1) with the 2 routers as in the above post
2) with the 4510R.
Is there a reason you want to use the 3825 routers to do the inter-vlan routing or have i misunderstood your requirements.
Jon
02-01-2008 09:02 AM
we need ot have the routers given the datacenters and connection between them. I am new to this company and still trying to see how they have done things.
We are building this new office with these new gears.
SUPare redundant and I can do routing on the switch so let's asssume that we do routing on the switch and see how we can configure this switch for those VLANs please.
I will be clear on the routers later. we will be having two different circuits, a 100 MB ether and a fractional DS3 as backup. so the 100MB will beused as the primary circiut. they are from two different ISps.
the routers are 3845.
Thi soffice will be facing a datacenter using the two circuits I mentioned above.
Please let me if more information is required.
Thx,
Mike.
02-01-2008 09:13 AM
Okay, if the 4500 has redundant sups then it would make sense to do the inter-vlan routing on the switch.
So
1) Create the vlans at Layer 2 ie.
4500(config-if) name Internal
4500(config)# vlan 3
4500(config-if) name External
2) Create the L3 interfaces for these vlans ie.
vlan 1
ip address 192.168.5.1 255.255.255.0
vlan 2
ip address 192.168.6.1 255.255.255.0
no shut
vlan 3
ip address 192.168.7.1 255.255.255.0
Clients in vlan 2 will have default-gateway set to 192.168.6.1 and clients in vlan 3 will have default gateway set to 192.168.7.1
3) Allocate ports on 4500 into vlans eg.
4500(config) int range gi3/1 - 20
4500(config-if-range)# switchport access vlan 2
For connectivity to the routers i would use 2 connections and make them routed links so you need 2 x /30 subnets eg.
192.168.4.0/30
192.168.4.4/30
Connect the switch to each router. Configure the port on the switch as
4500(config-if)# no switchport
4500(config-if)# ip address 192.168.4.1 255.255.255.252
4500(config-if)# no shut
The 3825 end of this link will be 192.168.4.2 255.255.255.252
4500(config-if)# ip address 192.168.4.5 255.255.255.252
The 3825 end of this link will be 192.168.4.6 255.255.255.252
Then you can run a routing protocol (EIGRP/OSPF etc) between your 4500 and the 3845 routers.
Jon
02-01-2008 09:19 AM
Thanks John,
this make sense and I beleive this is how they need tobe done.
if we decide to use no Routing protocols (IGP) at this time and stay totally Static, would it change the scenario at all?
Mike
02-01-2008 09:21 AM
Mike
Not really no. Your 4500 will automaticaly route between the vlans because they are directly connected and you can then add static for remote subnets on your 4500 pointing to both 3845's.
Remember to add routes on the 3845's to get back to the vlans on the 4500 switch.
Jon
02-01-2008 09:26 AM
John,
why did you came at this conclusion that because of th eredundant SUP, we can do routing on the switch and not the router?
what would change if router start to route the traffic?
thx,
Mike
02-01-2008 09:30 AM
Mike
I just assumed you wanted to do the inter-vlan routing with your 3845 routers initially and i wasn't sure if your 4500 was layer 2 only.
When we refer to the routing there are 2 things here
1) the routing between the vlans. This could either be done on the 4500 or using the 3845 switches. It would always make more sense to use the L3 switch for this.
2) Routing from the 4500 vlans to other remote subnets. The 3845 routers will do this for you giving your 4500 connectivity to other parts of your infrastructure.
Apologies if i misled you
Jon
02-01-2008 09:48 AM
John,
you are right and didn't miss my point at all. the fact is creating VLANs on the L3 siwtch makes all the sense and what you explian will take cae of my current issue with the initial setup of vlans for this office but you brought up another point which would have come up sooner or later and that is connectivity between the VLANs in this office and the VLANs in the datacenter and other remote offices?
We do need these vlans to communicate to other vlans in other offices across the nation or through two datacenters.
what do you recommend for this please?
I am sorry that i didn't thibk of this sooner and many thanks for bringing it up.
Mike
02-01-2008 10:06 AM
Mike
Jon
02-01-2008 10:13 AM
Thanks very much for you very helpful and detailed support information. You are right, you talked about L3 links to the routers so no L2 trunks.
I areally appreciate your help. I haev alreday rated your support!
Cheers!
Mike.
02-01-2008 09:54 AM
John,
one more thing, the uplink from the 4500 switch to the 3845 (both links) should be in truck mode?
Thx,
Mike
02-01-2008 07:37 PM
