VG224 SCCP SRST
gene
I have a vg224 at a remote site working fine on sccp. We also want it to fall to the SRST router in case of a wan failure. Does anyone have an example config of this or can anyone tell me how this should be configured to work properly?
val.mintchev
Level 4
Level 4
Greetings,
I'm attaching a config that is working with two CallManager subscribers and fails to the SRST router (identifier 30) in SRST mode.
IOS is 12.4.(15)T2
Val
Hey thanks. It looks like as far as the vg224 is concerned the SRST is just another call manager. Is there anything as far as dial peers you have to do in the SRST router or is it all automatic as with the ip phones?
The only dial-peers required are the ones for the stcapp application to control the FXS ports.
You don't need any VoIP dial peers. The SRST router controls the call routing in SRST mode.
Val
