CFwdAll-Message configuration
Feb 1st, 2008
I recently had my call manager server crash. I've restored it and got things going now, but one thing is still not working.
We have an overhead ringer that is assigned a DN. At night when the receptionist leaves she forwards all the calls to the night ringer so the shop can then pick up calls after hours. If a call is not answered it would eventually go to the main-number VMB.
Before the crash she was able to hit the CFwdAll softkey and then the messages button and that would set it. What enables this functionality?
Ginger Dillon Fri, 02/01/2008 - 15:28
Hi Ben -
There are two things that need to happen:
1. In CallManager, make sure the directory number is associated with a voice mail profile.
2. In CallManager, make sure the directory number has a CallForwardAll CSS configured.
P.S. You didn't mention your version of CallManager but I seem to recall a bug with CallFwdAll not getting set, I'll check the Bug Track tool and see if I can find anything. Found it before my Edit for the post disappeared - here's what I found -
Hope this helps!
benharned Mon, 02/04/2008 - 06:07
Sorry, I'm on 4.2(3). The bug you referenced is not the problem I am having, thank you anyway.
The number is assoicated with a VM profile, and is associated with a VoiceMail CSS, not a CallFwdAll CSS. (There never was one before the crash).
Why wouldn't the configuration be restored along with everything else?
benharned Thu, 02/07/2008 - 05:52
Issue resolved.
Turns out our receptionist misunderstood what happened when she CFwdAll to messages. It wouldn't ring our night bell immediately. It would go to an after-hours call handler and give the caller the option of zeroing out, and then the call would ring overhead.
There was/is no special prgramming needed on the phone.
THanks for the time!
