how to static a route between two different subnets
Feb 1st, 2008
In order for the Spectralink phones to talk to the Avaya IP phones we need to setup a route between the following subnets: (Specralink subnet) /23 (Avaya IP Phone subnet)
You may have the /23 as two separate subnets: /24 and /24.
If so, the /24 needs to talk to both subnets above
This is my clients request. I need someone to help me get these two different subnets to talk to eachother. Also, I need to know if his request makes no sense what so ever, then i need to know what questions i need to ask as I am having problems desifering his request.
Richard Burts Fri, 02/01/2008 - 10:13
Perhaps it would help if we could get some clarification about the network topology.
But it seems fairly straightforward. The router/layer 3 switch where the 10.111.131 subnet is located needs a route (a static route) to identify how to get to 172.16.0. And the router/layer 3 switch where 172.16.0 subnet is located needs a route to identify how to get to 10.111.131.
The main thing that you would need to have to do the static routes would be what the next hop address would be from each of the router/layer 3 switches.
shirwaziri1_2 Fri, 02/01/2008 - 10:34
BOSWF-Cisco4507R_RM183#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is to network is subnetted, 2 subnets
C is directly connected, Vlan601
C is directly connected, Vlan602 is variably subnetted, 9 subnets, 5 masks
C is directly connected, Vlan100
C is directly connected, Vlan200
C is directly connected, Vlan603
C is directly connected, Vlan902
C is directly connected, Vlan203
C is directly connected, Vlan204
C is directly connected, Vlan301
S [1/0] via
C is directly connected, Vlan604
S* [1/0] via
The routes are both configured on the switch. According to my coworker this is not a layer 3 switch. And instead, what we are thinking of is using IP helpers. Are you familiar with ip helpers?
does this make sense?
Richard Burts Fri, 02/01/2008 - 11:14
In your first description of the situation I assumed that the subnets were on different machines (routers/layer 3 switches). This output shows that all 3 subnets are connected on this machine (which from the name I would assume is a 4507 switch).
Depending on the supervisor the 4507 can function as a layer 2 switch or as a layer 3 switch. If it were functioning as a layer 3 switch then it would be very easy to ensure that inter VLAN routing is happening. If it is a layer 2 switch then you would need to find what it is connected to that can do inter VLAN routing, and you would need to make sure that VLANs 601, 602, and 604 (the VLANs where these subnets are connected) are trunked to that device.
Given what appears to be here I do not see where there would be need of a static route.
Rick Morris Fri, 02/01/2008 - 11:21
What Rick was trying to say is you need to tell the different subnets where to go for their traffic to the other subnets.
For example:
Network needs to talk to Network
You need to tell the network how to get there. So traffic from the 10 network needs to access you need a route statement like this:
ip route
This statement says that any traffic on that router/switch that needs to talk to needs to go this way, next hop IP or you could use an outbound interface.
Is this what you are looking for?
Or are you using the switch and putting the IP's/networks in VLAN's and need to do intervlan routing?
