Copy TFTP from a directory in FLASH
Feb 1st, 2008
I was wondering if the "HTML" directory in a 3500XL switch is able to be TFTP'd to my laptop? I was successful in copying over the .bin file (copy flash tftp), but when I issued the same command and tried to pull the "HTML" file it errored out with "HTML IS A DIRECTORY" Thanks for any/all replies!
Richard Burts Fri, 02/01/2008 - 11:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vince
I believe that it is not possible to TFTP the directory to your laptop. But if you identify the individual file of the directory and the correct path to the files then you should be able to TFTP the content of the directory to your laptop.
Rick
