Router failure
Feb 1st, 2008
Hi everybody,
I'm actually having a problema with a 2800 router. The issue is that it was working well. I turn it off to move from one rack to other,and then it never has come up again.
This is the output of what i see when i turn it on:
Readonly ROMMON initialized
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
After this, I am able only to rommon prompt.
I used the same flash memory in other router and it works well...
Is it a hardware failure then?
thanks and regards....
Richard Burts Fri, 02/01/2008 - 11:23
For the symptoms described, my first suggestion would be to make sure that the flash/compact flash is correctly and firmly seated. Then try to boot again.
ccnp_seeker Fri, 02/01/2008 - 12:22
I did it and the same behavior occurs.
Removed the flash and installed again, the same result....
I Used the flash in other router...and it works well...
I will try a new flash in the router to see what happens....
