02-01-2008 01:20 PM - edited 03-15-2019 08:34 AM
Hello all,
I am in the process of creating a new account for the operator to access the unity admin page to activate / deactivate messages durring certain times of the day.
The issue is, when they login and try to access the System admin webpage they get the following error
Your Windows Domain Account [VOICEMAIL00\5344] is not associated with a Cisco Unity Subscriber.
You cannot access the Cisco Unity System Administration.
Please see your system administrator for more details.
http://voicemail/web/Common/Error.asp?Kind=NoSubs
How do I associate it with the unity subscriber ?
Solved! Go to Solution.
02-11-2008 07:32 AM
ok, we're talking about different things here
one would be to create an account to admin Unity, and other thing to also manage exchange from the same account
if you want the same user to be able to use exchange you would need to open the exchange admin and right click on it and use the delegate control option over that account, also add the exchange permissions or exchange admin group to that user
02-01-2008 02:20 PM
you need to log into unity with the unityadmin account
open the unity tools and under diagnostic tools you will find a tool named Grant Unity Access
you need to know the account you're going to use and the subscriber to which you're going to associate
02-06-2008 09:08 AM
Nevermind Jav.. I was looking in the wrong Tools.. Found it and got it to work, thanks much
02-06-2008 09:46 AM
Ok.. so I added the user through the diagnostics page.. now I am getting the following when I try to open the system admin page
Access denied
Your class of service prohibits you from accessing the Cisco Unity System Administration.
Any ideas?
02-06-2008 09:51 AM
the subscriber to which you associated the user needs to have a class of service that allows him to make changes and log in, if you have the default subscriber COS you won't be allowed.
go into the subscriber page and look for the Class Of Service parameter
change it to the administrator one and try again
02-06-2008 10:08 AM
Sweet
Thanks for the help Jav, I think I got it from here.
02-11-2008 07:24 AM
Ok Jav, I lied i dont have it yet!
I got the login and the association working, but I am getting view errors when I try to give them access to a folder to view in the unity exchange folders. I gave the account domain admin and local admin access what gives?
02-11-2008 07:32 AM
