Unity 5 post install wizard
Feb 1st, 2008
I just did a fresh install of unity 5. The install went through the coping of files with out any errors, then had to reboot.
Usually after the reboot (at least in 4.x versions) another wizard opens up that allows you to install the license files, connect to a message store, etc. That never opened up.
Is it possible to manually run that wizard?
The real problem is that i can not import the license file through the viewer. It is giving the error "Error loading install path from registry". I want to run the wizard to make sure I didnt miss a step needed before installing the license file.
Thanks.
ranpierce Fri, 02/01/2008 - 14:28
  • Silver, 250 points or more
yes, is there a cuica icon on the Unity desktop? that is what you want to double click.
If there isn't one, let me know.
rlp
mhurley131 Fri, 02/01/2008 - 14:30
Nope...there isnt. I checked the unityinstall user desktop as well as administrator and unityadmin.
ranpierce Fri, 02/01/2008 - 14:34
let me find out how to invoke it then. hold on.
rlp
ranpierce Fri, 02/01/2008 - 14:57
my servers are already all installed and that icon goes away after everything is installed and configured.
I thought I could trick Unity into thinking it hadn't finished by tweaking the registry. Some of the steps it does work. Under software/activevoice/cuca/ there are different parts of the setup and each part has a hascompleted part. 1 is yes has completed and 0 is no. it is decimal.
Be careful if you play with the registry and remember TAC probably will not support any issues.
rlp sorry I couldn't fix it
mhurley131 Fri, 02/01/2008 - 14:59
I'll see if i can play with those reg entries and get it to come up on the desktop. Thanks for your help.
