ASA5505 No Internet Connectivity
Answered Question
Feb 1st, 2008
I am setting up a new ASA 5505. The old firewallhas a IP x1.x2.x3.x4, subnet 255.255.255.192, gateway g1.g2.g3.g4, DNS d1.d2.d3.d4. I am connected to a cable modem
I cannot connect to the internet. Can someone please help, I am new to Cisco.
Result of the command: "show config": Saved
: Written by enable_15 at 17:50:24.909 CST Fri Feb 1 2008
ASA Version 7.2(3)
hostname xxxxx
domain-name default.domain.invalid
enable password R8oXOL9vUpDFQFqu encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address x1.x2.x3.x4 255.255.255.192
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
name-server d1.d2.d3.d4
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 g1.g2.g3.g4 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 69.1.30.11
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd dns 192.168.1.1 interface inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:c654e7d7b9580738e2bc70d4c3f3b9d4
Correct Answer by oszkari about 9 years 3 months ago
yes
Overall Rating: 5 (1 ratings)
oszkari Fri, 02/01/2008 - 16:48
the configuration seems ok, you should have access to the internet.(if the ip, gw addresses are correct)
Do not check the internet access with ping, by default icmp packets are not permitted trough ASA.
greentw1972 Fri, 02/01/2008 - 17:12
I have double checked everything. Attempting to connect with IE and no luck. Tried 2 different computers. Is there anything else I need to setup? This is a new install. Could it have something to do with the cable modem? As I mentioned the current firewall, Syamantec is working with these parameters.
I will try again in the morning and post a log.
Thanks for you help.
oszkari Fri, 02/01/2008 - 17:16
no dhcpd dns 192.168.1.1 interface inside
set a real dns server
dhcpd dns your_provider_dns_server_address interface inside
srue Fri, 02/01/2008 - 17:59
  • Blue, 1500 points or more
try using 4.2.2.4 as your DNS server and see if that works
greentw1972 Fri, 02/01/2008 - 19:03
I have not entered the DNS provided by my IPS. However this entry is in my configuration.
dhcpd enable inside
Should I change the 192.168.1.1 to the 69.1.30.11?
excession Sat, 02/02/2008 - 08:20
Should one of your ports have "switchport access vlan 1"?
Can you ping the firewalls inside interface?
greentw1972 Sat, 02/02/2008 - 09:05
Setting the DNS worked. Thank you for your help.
Is there any other setting I need to make for security?
oszkari Sat, 02/02/2008 - 13:47
It depends on the needs...
Now you have a fully functional SPI firewall,
which drops all the traffic which was not initiated from the inside lan.
You could filter the outgoing traffic too and
do some application layer inspection on http...lot of exploits circulate these days..
