Warning message
TCL script for Mobile Connect
Feb 1st, 2008
I am designing a simple tcl script to predial PIN#*82# on the recieve of a call on the DID number for MiddleCall mobile connect features. It works but I have not found anything else that timer (min 1 sec) between 2 digits (between 2 runs of the script). It's too long.
Thanks for help
Guy
paolo bevilacqua Sat, 02/02/2008 - 11:15
  • Hall of Fame,
    Founding Member
Hi, can you explain again what is that you want to do and what is too long ?
guy.richard Sat, 02/02/2008 - 23:13
I use MobileConnect on CUCM601, once a user have recieve a call on his mobile from CUCM, he can achieve "mid-call features" like tranfer the call to an IP Phone.
He must dial *82 (hold) then the DID number of a gateway (10+digits can be memorized on mobile) the PIN (4 dig) then # then *84# then target DN # then *84 (total 32 digits).
I am designing a tcl script started in a dial-peer on the DID number.
I have shortened prefix *82 *1, *84 *2
I config same PIN for all these users
I transfer call to an receptionist
The user dials *1 + DID-fastDial
Then the script dials PIN#*2#551515#
Then the user dials *2
Only one digit is sent in dtmf each time the script is run. Timer 1 is used to go back to the script.
Is there another way to do that ?
Guy
paolo bevilacqua Sun, 02/03/2008 - 14:10
  • Hall of Fame,
    Founding Member
Ok, I guess what you are saying, is that the 1 second (minimum timer granularity) that is in between digits, makes the overall dialing time too long.
Have you tried simply invoking "leg senddigit" sequentially for all the digits comprising the number ? You can also use "clock clicks" to for a finer resolution timer between digits.
